Home » Audio » Speaker » Audio Nirvana Speakers
Re: Audio Nirvana Speakers [message #20806 is a reply to message #20805] Sun, 10 April 2005 18:54 Go to previous messageGo to previous message
Did you order any speaker enclosure plans with them? They seem to fit the 1.3 cu ft enclosure nicely. If I did this correctly you could use two 2-7/8" id by 5" long ports to achieve a tuning freq of 61hz. This gives a -3dB point of about 56hz, with a peak of less than 1dB at about 72hz. Regardless of what alignment you use I will be interested in knowing whether you are hearing more brightness in the 4-8khz range than you heard with the 206E's when they were new.
I'll definitely post a follow up, but it will be a while. For now I will say that the concern about the bass alignment is valid, but a variation of +3 / -2dB really isn't a big concern to me. The actual in-room response I have measured on speakers that are known have very flat anechoic response curves has varied by much more than this, especially below 200hz. As I mentioned in a previous post, in all fairness to these drivers I need to give them 100 hours of break in time and then do a critical evaluation.
Previous Topic: Yamaha SP1 - Digital Array for HT
Next Topic: Fostex break- in proceedures
Current Time: Mon Nov 09 01:00:45 CST 2026
