Home » Audio » Speaker » correction of high freq(206e in a Jeriko)
Re: correction of high freq(206e in a Jeriko) [message #20706 is a reply to message #20703] Fri, 25 February 2005 08:17 Go to previous messageGo to previous message
Martin is currently offline  Martin
Since the high frequencies are coming from the front of the driver, and not out of the horn's mouth, you have two choices. You can raise the SPL of the lower frequency output from the horn, which probably means a redesign of the horn itself. Or you can try and tame the high frequency output of the driver, which in my opinion the most controlled and predictable method would be with a filter. The filter will allow a significant amount of adjustment to the driver's response that is completely reversible.
Martin
Previous Topic: SFRD projects
Next Topic: Vott 210 and slot cars
Current Time: Mon Nov 16 06:38:04 CST 2026
