Home » Audio » Speaker » anyone know build this horn?
One in particular... [message #20614 is a reply to message #20613] Sun, 16 January 2005 11:25 Go to previous message
The Yamamura Dionisio.
Long gone now, but
At $25,000, Be Yamamura's full-range, single driver, multi-horn Dionisio is unlikely to show up at your local high end saloon, or in my system, for that matter. But after listening to a cone-driven Edgar mid horn for a few years, I am a champion of this concept. At a range of ten feet, metal midrange drivers can blast a hole in the wall behind your listening position. A horn loaded cone can really sing close in.
The Dionisio uses a modified Lowther PM-4 to drive this 2.3 m tall cork covered fiberglass sculpture between 27 Hz to 16kHz with better than 100dB efficiency. Said to play on two watts.
Yamamura has various smaller and larger versions of the Dionisio in the works, some priced down in the economy car range. Crazy price aside, paper cones, cork, and no crossovers sounds like a reasonable recipe to me.
US Representative:
Virtual Audio
POB 1598
Novato, CA 94948
415-898-8067
Previous Topic: Readers in the EU
Next Topic: 6.5" Woofer
Current Time: Sun Nov 22 23:49:30 CST 2026
