Home » Audio » Speaker » fostex rear loaded horn design
Re: fostex rear loaded horn design [message #20600 is a reply to message #20557] Wed, 12 January 2005 10:12 Go to previous messageGo to previous message
robertG is currently offline  robertG
Most (all?) designs call for a simple cap, 6 dB/octave. With 2 or 3 caps, you can experience different Xover freq. Since the T90A is more sensitive than the 206 (or any other Fostex FR), you can cross it all the way up.
For example, if crossed at 20KHz, you will still have a -6dB output at 10KHz (wich would be OK, given the difference in sensitivity). The idea of crossing the supertweeter very very high is bypass any need for a resistor in the circuit.
You will also notice that those BLH with super tweeters ar the larger one (8 inches and up), so if you have a smaller room, you might just go for a 6.5in. and do without the ($$$) tweeter.
Previous Topic: CORAL Flat 8A drivers on open baffles
Next Topic: Hi-Efficiency vs Lo-Efficiency Speakers
Current Time: Fri Nov 06 01:27:00 CST 2026
