Home » Audio » Speaker » correction filter for Fostex fe206e in a Jeriko
Re: correction filter for Fostex fe206e in a Jeriko [message #20586 is a reply to message #20585] Fri, 07 January 2005 10:22 Go to previous messageGo to previous message
Your 19mm baffle should be fine, you can double the baffle like you've said just as long as it dosn't interfere with the back wave feeding the horn but I don't see where you need to, it'll just add more weight(lb's) to the speaker. Hope you got a forklift to move the things after your done there going to weigh a ton with double sides, back and sand filling.
Bill W.
Previous Topic: Choosing array, please help...
Next Topic: Favorite flavors
Current Time: Sun Nov 01 02:20:56 CST 2026
