Home » Audio » Speaker » Legend 875
Impedance at resonance [message #20482 is a reply to message #20480] Mon, 11 October 2004 11:11 Go to previous messageGo to previous message
Hi Akhilesh,
There is an impedance peak at resonance, that is true. If the driver is mounted on an open baffle, it will have an impedance peak at fs. If it is put in a sealed box, then the resonant frequency will rise to fo, but the system will still exhibit a single peak. If used in a vented system, then there will be two impedance peaks at fl and fh. And if used in a horn or transmission line, there will be several impedance peaks from the cutoff frequency up.
Wayne
Previous Topic: auto tuba mouth extension
Next Topic: JBL 2242H
Current Time: Sun Nov 29 03:31:52 CST 2026
