Home » Audio » Speaker » SET/PP/SS and when to use them
Re: SET/PP/SS and when to use them [message #20450 is a reply to message #20446] Thu, 23 September 2004 20:09 Go to previous messageGo to previous message
TC is currently offline  TC
>> If so what would be a natural match
==Assuming you have a high efficiency single driver. Low powered SET, lower the better. Best by a longshot. Newer current source amps (firstwatt) are a new form of yet undiscovered sweetness.
>>what would be a obvious mis-match?
==High powered SS. High voltage gain caused by multi gain stages inserting phase adjustments at every push. Sounds fine covered up and padded with cap coupling and heavy loads. Works great on speakers that have low impedance with consumer grade sources. These amps always start to sound great at about 45% of their rated power.
I won't bore you with a list of my amp collection. I will say solid state is not completely hopeless (see Firstwatt white paper at www.firstwatt.com for more of the same).
TC
Previous Topic: Posts?
Next Topic: Line array enclosure
Current Time: Sun Nov 22 23:26:12 CST 2026
