Home » Audio » Speaker » fostex design search results
Re: fostex design search results [message #20427 is a reply to message #20426] Tue, 21 September 2004 18:54 Go to previous messageGo to previous message
Martin is currently offline  Martin
"I mean if you need a filter, then whats the point?"
Why would you make such a strong statement? If a filter improves the overall performance of the system, why not use it? Would you rather listen to an unbalanced overly bright shouting full range speaker system and be happy knowing it is still "pure" due to the lack of any filter while it continues to hurts your ears?
Not me, I'll take the filter. A filtered full range is still much better then a two way in my opinion, and also better then an unfiltered full range in most cases. I have successfully designed and built both multi-way and single driver systems and really prefer the filtered full range Lowthers.
Martin
Previous Topic: Line array enclosure
Next Topic: Bandpass subs
Current Time: Tue Nov 24 17:31:19 CST 2026
