Home » Audio » Speaker » Single driver cornerhorn
Re: Single driver cornerhorn [message #20371 is a reply to message #20370] Fri, 10 September 2004 13:04 Go to previous messageGo to previous message
A 50 hz horn is a 50 hz horn. Corner loading wll allow a smaller mouth(which will mean a shorter horn) but depending on the throat size and type flare will still have to be a given length.
Only reason i havent spent a lot of energy in corner horns is the lack of room geometry.
IMO a corner horn should be just that, designed for a corner horn and not just a rear firing horn.
ron
Previous Topic: More thoughts on slot vs. hole for mounting array drivers
Next Topic: hammer dynamics
Current Time: Fri Nov 06 02:30:16 CST 2026
