Home » Audio » Speaker » BR + TL + FH
Re: BR + TL + FH [message #20363 is a reply to message #20352] Sun, 05 September 2004 18:21 Go to previous messageGo to previous message
Martin is currently offline  Martin
Ralph,
I really do not know the answer to your question. In most cases you are looking to maximize the bass output to balance the mid and high end. You can use a back loaded horn to offset the baffle step but as you say the size becomes an issue. I don't see any easy way to get the volume of bass required to run a speaker system without a BSC circuit without it becoming very large like a back loaded horn. Bass reflex, TL's, TQWT's and closed boxes do not seem to produce this type of bass volume.
Martin
Previous Topic: Line array question using Bandor 50mm driver?
Next Topic: Doppler distortion
Current Time: Sat Oct 31 15:22:06 CDT 2026
