Home » Audio » Speaker » BR + TL + FH
Re: BR + TL + FH [message #20352 is a reply to message #20345] Sun, 05 September 2004 09:52 Go to previous messageGo to previous message
Ralph is currently offline  Ralph
Thanks for your input, Martin. A dual horn might be the best bet.
However, on a purely technical standpoint, do you think a speaker can be made that uses Helmholtz and pipe organ resonation, both and at the same time? Rear horns are so large and I hoped to make a smaller box.
Thanks,
Ralph
Previous Topic: Line array question using Bandor 50mm driver?
Next Topic: Doppler distortion
Current Time: Sat Oct 31 15:19:03 CDT 2026
