Home » Audio » Speaker » BR + TL + FH
Re: BR + TL + FH [message #20349 is a reply to message #20344] Sat, 04 September 2004 19:09 Go to previous messageGo to previous message
robertG is currently offline  robertG
This require some thoughts! At first, I would beleive that the setup would be high-mid heavy. Did you try to model it in sim software?
Would it be superior to a FH + BH setup? In my experience, a back horn will "boost" output from probably 50Hz all the way to 300 Hz, which might be all you need. On the other hand, your idea would probably yield to a smaller (and easier to design) and more convenient (as in WAF) package... Hum...
Previous Topic: Line array question using Bandor 50mm driver?
Next Topic: Doppler distortion
Current Time: Sat Oct 31 15:17:08 CDT 2026
