Home » Audio » Speaker » Front horns
Re: Front horns [message #20302 is a reply to message #20301] Mon, 23 August 2004 00:15 Go to previous messageGo to previous message
JeffM is currently offline  JeffM
I think I get it. You don't make a compression horn with a full range driver, for a front horn you just add a flare with no compression. This makes it act differently. The idea is to get a mild gain, more of a directional edge than anything else. The response boost is light and complements the driver sort of like a back horn. Is that about right?
Previous Topic: DIY
Next Topic: "Ambience" Supertweeter
Current Time: Mon Nov 16 06:03:56 CST 2026
