Home » Audio » Speaker » Using filters on lowther type drivers
Re: Using filters on lowther type drivers [message #20224 is a reply to message #20221] Wed, 28 July 2004 16:28 Go to previous messageGo to previous message
Martin is currently offline  Martin
akhilesh,
You know I love filters. You also know that the Lowther measurements on my site clearly show the peak you describe. But for this particular peak, I would probably not use a filter. All you need to do is listen about 10 degrees off axis and the response is nice and flat and does not start to roll - off too bad at higher frequencies. A second option is a phase plug, there is a site linked ftom mine that shows Lowther DX3 measurements with several different styles of phase plugs. I have a growing collection of Lowther phase plugs and can state that they can be used to tame this on axis peak.
Hope that helps,
Martin
Previous Topic: Has Anyone Else Had This Experience?
Next Topic: What's your favorite driver from 20-200 Hz?
Current Time: Tue Nov 03 17:39:15 CST 2026
