Home » Audio » Speaker » Phase plug mod
Re: What does the phase plug do? [message #20215 is a reply to message #20211] Wed, 28 July 2004 07:34 Go to previous messageGo to previous message
robertG is currently offline  robertG
The phase plug is not attached to the cone in any way. When you remove the dust cap, you see a hole, that's the inside of the voice coil former. At the end of the hole, you see the back plate. The phase plug is glued to the back plate and should be clear of the voice coil. Some speakers do have a bullet shaped dust cap acting as a phase plug. This kind of phase plug is glued to the cone and its weight is figured in the driver design. But the wooden "light bulb" phase plug of tweaked lowther drivers is not glued to the cone.
Hope this help a little
Previous Topic: speaker power
Next Topic: Has Anyone Else Had This Experience?
Current Time: Wed Sep 23 22:35:26 CDT 2026
