Home » Audio » Speaker » Any ideas for a cabinet design?
Re: Any ideas for a cabinet design? [message #20184 is a reply to message #20176] Mon, 26 July 2004 08:23 Go to previous messageGo to previous message
Hi SFR,
For the woofer (peavey scorpion 10), you can build a box: 36" high X 14" wide X 18" deep. Use 3/4" baltic birch or MDF to build the box (or get a carpenter to build it). In the box, make a hole for the driver at ear level, and another hole (slightly away & down from the driver) of diameter: 4.3". This second hole can be 4 " or more from the ground.
For the tweeter, you can use either a horn configuration, if you know how to calculate and build one, or alternately, just use a dome tweeter. Crossover freq will depend on the woofer curves. Make sure the efficiencies match (in other words look for a tweeter with eff close to 99 db). PArts express may have them. (www.parts-express.com)
hope this helps. tell us what you did and how it turned out!
-akhilesh
Previous Topic: pairing speakersw to tube amps
Next Topic: choices, choices
Current Time: Fri Nov 06 03:09:01 CST 2026
