Home » Audio » Speaker » Completed My Voigt Pipes Today
Re: Please don't take this the wrong way.... [message #20165 is a reply to message #20164] Sun, 18 July 2004 19:26 Go to previous messageGo to previous message
FredT300B is currently offline  FredT300B
Glad you liked all the eye candy. Something I forgot to mention in the picture captions: It's best to coat the entire piece with the 50/50 glue & water mixture and not just the rough edges. The mixture will, like water, raise the "grain" of the mdf, so you need to sand it thoroughly after it's dry, and if you have the patience it doesn't hurt to do a second coat and sand again. This will give you a smooth hard non-porous painting base that allows the automotive-like satin gloss that looks so good on a painted enclosure. If you do not use the glue/water mixture you're going to have to apply many many coats of paint and still have rough edges.
Previous Topic: Cancellation in car trunk
Next Topic: Enclosure for Fostex 167E
Current Time: Sat Nov 28 23:53:33 CST 2026
