Home » Audio » Speaker » Looking for T/S specs for EV LS-8
Found them [message #20063 is a reply to message #20058] Thu, 03 June 2004 10:39 Go to previous messageGo to previous message
Found them, thanks to elcraigo over on the Fullrange Driver Forum.
Dave
>elcraigo
Re: Need T/S parameters for EV LS-8
T/S for (2) LS8 I measured:
EV - LS8 Sample #1
"Fs = 76.000 Hz"
"Zmax = 15.825 ohms"
"Re = 5.600 ohms"
"Zdb3 = 10.954"
"F1 = 59.781 Hz"
"F2 = 95.587 Hz"
"Qms = 4.152"
"Qes = 1.469"
"Qts = 1.085"
"Le = 0.1970 mH"
"FsA = 48.000 Hz"
"Sd = 248.286 sq.cm"
"Cms = 0.3304 mm/N"
"Mms = 0.01327 kg"
"BL = 4.915 Tm"
"n0 = 0.82976 %"
"Vas = 28.807 liters"
"SPL = 91.208 dBSPL 1W/1M"
EV - LS8 Sample #2
"Fs = 80.000 Hz"
"Zmax = 10.756 ohms"
"Re = 4.780 ohms"
"Zdb3 = 8.617"
"F1 = 63.473 Hz"
"F2 = 100.614 Hz"
"Qms = 3.883"
"Qes = 1.726"
"Qts = 1.195"
"Le = 0.1565 mH"
"FsA = 48.000 Hz"
"Cms = 0.3518 mm/N"
"Mms = 0.01125 kg"
"BL = 3.958 Tm"
"n0 = 0.87721 %"
"Vas = 30.671 liters"
"SPL = 91.449 dBSPL 1W/1M"
some elcraigo T/S
Previous Topic: How do you calculate the optimal back chamber size for a frontloaded bass horn?
Next Topic: Good, better, best
Current Time: Thu Nov 05 22:57:17 CST 2026
