Home » Audio » Speaker » Backhorns
Re: Backhorns [message #19990 is a reply to message #19989] Fri, 07 May 2004 09:37 Go to previous messageGo to previous message
Well a back horn works on several principals. The first being the changing of pressure to amplitude ,which a TL dosent do.A backhorn is , in essence, a 1/2 wave resonator that has to be 1/4 wave minimum length.The higher efficency comes back from the flare rate , a very tight flare, ex. hyperbolic, can have up to a 70% conversion from electrical energy to mechanical. A conical will be quite a bit lower.However the tighter flare will increase distortion.The main factor in a horn is its ability to cover 3-4 octaves in gain, where a BR would cover around 1/2 octave, as well as the perception of "speed".You add to this the TL action and you get superior (in some designs) results.
Its all in what you really want.I switched from TLs and TQWT (kinda TL,BR,horn action)simply due to the extreem dynamics and reality of the sound.
ron
Previous Topic: LC tuning instead of ports
Next Topic: Isophon Speakers/Drivers
Current Time: Thu Nov 05 10:33:03 CST 2026
