Home » Audio » Speaker » Effects of a low pass notch filter on BR versus TL: speculations
Re: Effects of a low pass notch filter on BR versus TL: speculations [message #19905 is a reply to message #19880] Wed, 31 March 2004 21:31 Go to previous message
A transmission line has a primary resonant frequency, but it also has multiple harmonics above that. So I would expect a transmission line to have more resonances than a bass-reflex cabinet, with the TL acting sort of like a horn.
True, but in a straight TL the harmonics are in an odd multiple order.In a TQWT the harmonics are in an even order(closer together) which gives a greater LF response bandwidth.
Even though the TQWT will not go quite as low as a TL in frequency (given the same sound path length)i like the TQWT a bit better as the LF has a better response over a greater frequency range.
ron
Previous Topic: Xmax,Xbl2,Distortion
Next Topic: Can't reproduce a square wave
Current Time: Mon Oct 05 07:40:27 CDT 2026
