Home » Audio » Speaker » Martin Kings's cabs w/ FE206E's done
Re: Martin Kings's cabs w/ FE206E's done [message #19878 is a reply to message #19877] Wed, 24 March 2004 10:57 Go to previous messageGo to previous message
HI Jim,
Sounds good. I would love to hear it, and compare it to Phil's 206 full ranges.
You should know that the "inductor" i was using when you came to my place was not appropriate (too high a resistance) and you will need to order one from parts express or some other place. Make sure the resistance is as low as possible.
BTW, after i figured that out, i did get a good inductor from PE, and the difference is MUCH more than before. MUCH better bass. I suspect you will find that too. What you have right now is pretty much a series resistance, probably, which is raising the Q but not contouring the response as an inductor would.
thanx
-akhilesh
Previous Topic: Building YOUR single driver speaker:
Next Topic: Plan for april meet
Current Time: Fri Nov 13 08:26:10 CST 2026
