Home » Audio » Speaker » Boomtoobz
Re: Boomtoobz [message #19842 is a reply to message #19841] Fri, 12 March 2004 17:48 Go to previous messageGo to previous message
It will be good to get Martin's take on your project. My thoughts are that you'll have three primary pipe resonances. The first being set by the entire pipe length, the second by the longer section between the speaker and the floor bend and the third set by the length of the shorter section between the floor bend and the opening termination. Then there will be harmonics for each of those.
Previous Topic: Pretty Stuff
Next Topic: New revised subhorn plans
Current Time: Fri Oct 30 15:04:45 CDT 2026
