Home » Audio » Speaker » Rationale for single driver speakers
Re: Rationale for single driver speakers [message #19705 is a reply to message #19704] Fri, 16 January 2004 15:10 Go to previous message
So far, I've only tried two, the EV T-35 and a piezo (using a crossover and matching transformer). The piezo just barely makes it as far as sensitivity goes when hooked with my EV LS-12's (crossed with either a 1 uF or a 1.5 uF cap and transformer with 50 ohm resistor). The T-35 is much more efficient then the piezo, but I kind of like the piezo's sound. I have damped the horn on the outside with plumbers putty, also.
Both tweeters work well, but I would like to experiment more before making a recommendation, like using a different horn tweeter, or maybe a ribbon (if I can find an affordable one with enough sensitivity, about 95 dB).
Dave
Previous Topic: Whiteley Stentorian HF-1012's
Next Topic: Difference between studio monitors and home speakers?
Current Time: Mon Nov 02 17:13:53 CST 2026
