Home » Audio » Speaker » vintage 8" fullrange speakers
Re: vintage 8" fullrange speakers [message #19681 is a reply to message #19674] Tue, 06 January 2004 10:47 Go to previous message
Doesn't look too bad. If you can measure the T/S parameters, it seems like a bass reflex box would be good for this one. It looks like they may need a box tuned to about 50-60Hz HZ. You should get decent bass down to 50 HZ with this.
Why don't you try building a cheap box with a vent and seeing how it sounds? Start with a cheap box, about 1 or tw cubic feet. If it's two cubic feet, make the vent as a 3 inch diamter circle, with no need for a vent tube or anything. USe 3/4" MDF or birch ply. See how it sounds. Let us know!
thanx
-akhilesh
Previous Topic: Re: Before anyone can answer...
Next Topic: New! Improved???
Current Time: Sun Oct 04 04:51:56 CDT 2026
