Home » Audio » Speaker » Full range speaker
Re: Full range speaker [message #19662 is a reply to message #19660] Fri, 26 December 2003 11:03 Go to previous message
Now that is an interesting driver. The graph shows the response in a 50cu. litre box tuned to 60Hz, but doesn't show what kind of box. With a box that boosts low end, this could be a driver that covers all the important frequencies and just needs a sub for the lowest couple of octives and a super tweeter for the highest sounds. With that kind of sensitivity, any amplifier could drive it, and it comes in both 8 ohm and 16 ohm, to get even better amp matching (on a typical tube amp with the 16 ohm setting, these speakers could really put out some efficient sound). Sitting a bit off axis should tame the high frequency peak.
Of course, you can't tell what it will sound like untill you try it. ;^)
Dave
Previous Topic: Altec Valencia tweaks...
Next Topic: Has anyone heard of DCC Audio?
Current Time: Fri Nov 06 06:21:12 CST 2026
