Home » Audio » Speaker » Basic requirements for phase plug in horn loaded cone driver?
Re: Basic requirements for phase plug in horn loaded cone driver? [message #19589 is a reply to message #19588] Mon, 01 December 2008 18:03 Go to previous messageGo to previous message
Thanks JLH for your reply.
What I gather from your input is that a phas plug is pretty useless for midrange frequencies and below.
But, may beneifit a wideband driver intended to be used above 3kHz, like a Lowther 6" in the Azura horn.
Is there any benifit in using a phase plug for a driver intended to be used from around 150Hz and up to around 2kHz in a horn?
Looking at several pro drivers that use a phase plug. I see that they are mostly midrange types like the Beyma 6M180, that have a fairly high frequency extention of 6kHz or more.
Are there any specifications for a midrange, or midwoofer that would help indenify possible use for horn loading?
Thanks
Norris
Previous Topic: Audio Note AN-K - Changing internal wiring from silver to copper
Next Topic: using a wall of 15" woofers for bass.
Current Time: Sun Nov 08 12:25:29 CST 2026
