Home » Audio » Speaker » Basic requirements for phase plug in horn loaded cone driver?
Re: Basic requirements for phase plug in horn loaded cone driver? [message #19588 is a reply to message #19587] Mon, 01 December 2008 11:32 Go to previous messageGo to previous message
JLH is currently offline  JLH
Norris,
There is no reason to use a phase plug in front of a woofer. Its job is to increase high frequency extension, not something you want in a basshorn. Even midbass would be something not worthwhile. Midrange, possibly. Tweeter, definitely.
The whole purpose of a phase plug is to make path length the same from all points on the cone/diaphragm to the throat. Without one, sound eminating from the edge travels futher than sound coming from the center. The difference causes a phase shift and if enough, cancellation. That's why high frequency suffers without a phase plug.
Rgs, JLH
Previous Topic: Audio Note AN-K - Changing internal wiring from silver to copper
Next Topic: using a wall of 15" woofers for bass.
Current Time: Sun Nov 08 12:25:34 CST 2026
