Home » Audio » Speaker » MTM vs vertical MM and summing?
Re: MTM vs vertical MM and summing? [message #19584 is a reply to message #19582] Thu, 06 November 2008 23:18 Go to previous message
Horizontal directivity of a direct radiator is approximately 90° at the frequency where diameter equals wavelength. This is a good place to crossover to a 90x40 horn, because the horizontal directivity matches.
Vertical directivity is determined by the spacing of the drivers, their coverage patterns and the crossover frequency, phase and slope.
You can always put the drivers on a baffle, then measure to find the appropriate crossover points and slopes to put the nulls where you want them to be. Of course, you have to be in the ballpark when positioning the drivers on the baffle, but the end result is determined by the overlap frequencies and phase, which is set by the crossover.
Previous Topic: Electro voice
Next Topic: How to burn-in array speakers
Current Time: Fri Nov 06 01:43:21 CST 2026
