Home » Audio » Speaker » Help with crossover: Bipole surround speaker
Help with crossover: Bipole surround speaker [message #19575] Sun, 05 October 2008 08:18 Go to previous message
Kim Schultz is currently offline  Kim Schultz
Hi.
I´m about to put the finishing touches on four dipole speakers.
These speakers will be used as surround left, right and surround back.
The speakers have one Eminence Beta 8A woofer and two BMS 4524 1" drivers, mounted on 18Sound XT120, it is a 21 Litre ported cabinet tuned to 60hz.
Eminence Beta-8A
BMS 4524 1" driver
18Sound XT120 Horn
The last couple of days I´ve read alot about matching directivity both in the vertical and horisontal plane, but don´t know how much this means in a dipole speaker.
I have thought of a crossover freq. about 2khz, but I´m not sure how to hook up the compression drivers.
They need a bit of top end eq, and if I hook them up in series for a 16ohm load, I don´t know if they have enough sensitivity to be eq´ed flat.
Previous Topic: Design Stage : a 4-way system
Next Topic: Vifa DQ25SC16-04
Current Time: Sun Nov 08 20:39:46 CST 2026
