Home » Audio » Speaker » Design Stage : a 4-way system
Re: Design Stage : a 4-way system [message #19570 is a reply to message #19568] Fri, 26 September 2008 18:38 Go to previous message
Scott L is currently offline  Scott L
Yes, I have been thinking about this for a while now. My brief stint in thinking I could use 4 woofers per channel has now been eradicated due to the heighth requirement. The mid/ hi is going to be D'appolito, and I need that tweeter almost exactly dead center ear level. The mid-bass has to be a short length waveguide as oppposed to a true horn. I once built a mid horn with a four foot path length, and you are correct Wayne, the phasing was all off.
To help clarify: the 2x 12" pro woofers per channel will be side by side, but angled in towards each other. Some day I will have a picture, and it will be worth a thousand words.
Previous Topic: BMS 2193 horn?
Next Topic: Help with crossover: Bipole surround speaker
Current Time: Sun Nov 08 20:30:27 CST 2026
