Home » Audio » Speaker » Design Stage : a 4-way system
Re: Design Stage : a 4-way system [message #19568 is a reply to message #19565] Tue, 23 September 2008 14:16 Go to previous messageGo to previous message
That's a tough design choice, isn't it? Another thing to consider besides those you've mentioned is path length and how it affects summing. To get the sounds sources to sum properly, you'll need to delay everything else, otherwise phase will be way off.
Previous Topic: BMS 2193 horn?
Next Topic: Help with crossover: Bipole surround speaker
Current Time: Sun Nov 08 20:30:24 CST 2026
