Home » Audio » Speaker » diffractionless horns
Re: diffractionless compression drivers [message #19540 is a reply to message #19539] Mon, 23 June 2008 17:58 Go to previous messageGo to previous message
You're right that there is diffraction within driver, itself. The compression chamber and phase plug cause diffraction before it ever enters the horn. I suppose you could remove the phase plug and compression chamber, putting the diaphragm at the entrance of the throat and having throat area equal to diaphragm area. But that would reduce efficiency and bandwidth, so I'm not sure it would be a trade you would want to make.
Previous Topic: ping kloss
Next Topic: Best value for tweeters for La apps? Maybe... horn loading?
Current Time: Fri Oct 16 16:22:38 CDT 2026
