Home » Audio » Speaker » cd horns: conic, os, quadratic...........
Re: Constant directivity tweeter horns and waveguides [message #19477 is a reply to message #19476] Wed, 02 April 2008 17:43 Go to previous messageGo to previous message
At frequencies where the radiator is acoustically small, the wavefront is basically an omnidirectional sphere. If on a baffle, it becomes a hemisphere in the range of frequencies where the radiator is acoustically small but the baffle is acoustically large. As frequencies goes up, so that the radiator becomes acoustically large, the beamwidth will narrow.
A conical horn is like a baffle that narrows directivity smaller than 180°. Wavefront is basically spherical, bounded by the wall angle. Like the baffle mounted condition, this holds true through the range of frequencies where the throat is acoustically small and the mouth is acoustically large. Above and below this range, the pattern is no longer set by wall angle.
Previous Topic: Realistic Mach crossovers
Next Topic: Can I remove harmonic distortion with crossover?
Current Time: Sat Nov 07 07:58:00 CST 2026
