Home » Audio » Speaker » cd horns: conic, os, quadratic...........
Re: Constant directivity tweeter horns and waveguides [message #19476 is a reply to message #19475] Wed, 02 April 2008 13:46 Go to previous messageGo to previous message
Randy is currently offline  Randy
"If the sound source was a perfect radiating sphere of acoustically small dimensions and the throat was conical and acoustically small, I think all wavefront progogation through the horn would be this way. Or if it generated perfect planar waves and the exit was a tube, either way."
Compression drivers use of the phase plug is to make wavefronts diverge to approximate a planar wave AFAIK. However, cones and domes make omnidirectional spherical waves.
From this I would think a pure conical horn would be the best way to load a dome or cone driver. Your thoughts?
Randy
Previous Topic: Realistic Mach crossovers
Next Topic: Can I remove harmonic distortion with crossover?
Current Time: Sat Nov 07 07:57:53 CST 2026
