Home » Audio » Speaker » Pick the right mid/woofer
Re: Pick the right mid/woofer [message #19448 is a reply to message #19446] Thu, 21 February 2008 20:39 Go to previous message
ttan98 is currently offline  ttan98
I am using it in box and like to keep the Vas low less than 55litre, alpha 15a(more suitable for OB) has too large Vas, hence not suitable in this design.The woofer that suits this design should be 10" or less, I used Usher 7" woofer, it seems fine however the efficiency is very low, 87db not suited for my purpose.
thanks for your input.
Previous Topic: Speakerlab K Horn
Next Topic: Beta 8A in a 2-way
Current Time: Fri Nov 13 06:29:25 CST 2026
