Home » Audio » Speaker » Pick the right mid/woofer
Re: Pick the right mid/woofer [message #19445 is a reply to message #19444] Thu, 21 February 2008 17:23 Go to previous messageGo to previous message
ttan98 is currently offline  ttan98
Normal Delta 10A is not so suitable as the resonance freq. is a little higher than I need. Delta 10A, Rs=66Hz. At this freq. I cannot get the bass low enough for a 2 way to sound decent.
The neodymium magnet technology used in Deltalite, what you think of it? will it affect the midrange which emminence is famous for? Any idea?
Thanks for your input.
Previous Topic: Speakerlab K Horn
Next Topic: Beta 8A in a 2-way
Current Time: Fri Nov 13 06:00:28 CST 2026
