Home » Audio » Speaker » B&C ME10
Re: B&C ME10 [message #19439 is a reply to message #19433] Wed, 13 February 2008 21:06 Go to previous messageGo to previous message
ttan98 is currently offline  ttan98
I bought the combo from PE, the BE10 ia recommended by Magnetar and yes it made from Mylar, I am very happy with it, very smooth even when new. I cross over at the minimun freq.,ie 2.5Khz min freq. recommended by the manufacturer. It sounds fine to me.
I have not measured the combo, remember this combo is very cheap and when compared to the expensive brother, BE250(if you have the money buy this unit), I strongly suspect it will dip at higher frequencies, probably above 10-12Khz. I use an active x-over I can easily equalise it.
The combo is well worth a try, less than $60 per side.
Previous Topic: Voice Matching Polk Monitor 40s
Next Topic: Rogers LS7T
Current Time: Wed Oct 21 08:00:51 CDT 2026
