Home » Audio » Speaker » Maximum efficiency? Sensitivity?
Re: Maximum efficiency? Sensitivity? [message #19418 is a reply to message #19417] Fri, 18 January 2008 16:42 Go to previous messageGo to previous message
Efficiency is the ratio of the total acoustic power radiated from a speaker to the electrical power applied to it. Directionality isn't considered, rather, the total radiated power in all directions is compared with the input power. Impedance doesn't matter either, since power is what's being compared, not voltage. To provide a specific power level to the voice coil, the proper voltage must be applied according to its impedance.
Sensitivity is often called efficiency but the two aren't really the same thing. The sensitivity figure includes the effects of impedance and directivity. It is impossible for any speaker or group of speakers to exceed 109dB/W/M with a radiation pattern that is omnidirectional. That's because an omnidirectional sound source radiating 1 acoustic watt will measure 109dB at 1 meter distance in any direction. You can't exceed 100% efficiency, so it isn't possible to get more than 109dB/W/M from an omnidirectional sound source. But if a speaker or array is highly directional and focuses most of the energy on one spot, it can exceed 109dB with 1 watt input measured 1 meter away. Also, if the voltage is fixed, then SPL increases as impedance decreases. For example, if the reference voltage is 2.83v, then 1 watt of power is dissipated across an 8Ω load, but 2W is dissipated across a 4Ω load. So if voltage is fixed, SPL is higher if impedance is lower.
Previous Topic: Double ART Array?
Next Topic: Is this test valid?
Current Time: Tue Oct 20 19:08:46 CDT 2026
