Home » Audio » Speaker » Determining Low Freq Cut Off Of Folded Horn Box
Re: Determining Low Freq Cut Off Of Folded Horn Box [message #19409 is a reply to message #19283] Wed, 26 December 2007 09:34 Go to previous messageGo to previous message
Jeffery L is currently offline  Jeffery L
I have built a Bill Fitzmaurice Auto Tuba and I put it in my car. It was built with a width of 12", which is about the smallest you would want to build it, 15" width is the recommended. I would say it responds well down to 25Hz-30Hz. If it goes any lower than that I cannot hear it. If it was built wider the lower end response would be alot better. In a car there is a good deal of cabin gain.
I used the 8" MCM woofer, purchased for about $35. Don't be discouraged by the small driver as this horn will easily keep up with a decent 12" or 15" speaker that are using a lot more power. I am using less than 100 watts at any given time, most of the time less than ten watts.
BTW way, I like to listen to a lot or rap, metal, sometimes some Josh Groban (for the wife). It easily keeps up with any music. The bass is very precise and tight at any sound level.
This is the speaker I used
http://www.mcminone.com/product.asp?product_id=55-2421&catalog_name=MCMProducts
These are three different reviews,each differing in use and design.
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=1539
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=4201
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=3682
Previous Topic: Can car coaxs be used in line arrays?
Next Topic: thourght I'd show y'all my latest...
Current Time: Sun Nov 08 11:23:16 CST 2026
