Home » Audio » Speaker » Klipsch RS-7 clone
Re: Klipsch RS-7 clone [message #19361 is a reply to message #19360] Tue, 25 September 2007 08:53 Go to previous messageGo to previous message
If what you're talking about is a sealed or vented cabinet for the midwoofer with a pair of flanking tweeters, then you could probably use the Beta 8 just fine. A pair of ASD1001 tweeters mounted similarly to the Klipch RS-7 could be setup to work nicely.
I wouldn't configure the tweeters as a dipole though, because to do that, they would need to be wired out of phase. The idea is to reduce side radiation by cancellation. A dipole radiation pattern forms two lobes, in front and in back. If the horns in an RS-7 were configured as dipoles, you would have no treble out in front of the speaker, only out to the sides in narrow lobes directly on-axis in front of each tweeter.
I'd wire the tweeters in phase, and attenuate them to match the midwoofer.
Previous Topic: Connecting speakers via cat6 cables to a computer
Next Topic: New Project
Current Time: Thu Nov 05 22:22:14 CST 2026
