Home » Audio » Speaker » JBL 2225H reconed as a 2235H?
Re: JBL 2225H reconed as a 2235H? [message #19323 is a reply to message #19321] Wed, 18 July 2007 14:53 Go to previous messageGo to previous message
The 2225 does have the shorting ring, yes. The 2235 is tuned lower and is better for a subwoofer. The 2225 is better for a wide range high-efficiency woofer. Both are great woofers. The 2225 sounds wonderful in a slightly overdamped alignment, corner loaded. The 2235 sounds great in a max flat alignment, set out away from room boundaries.
Previous Topic: Wayne, does Speakerworks use JBL cones for repair?
Next Topic: DCX crossover installed
Current Time: Sat Oct 31 15:41:34 CDT 2026
