Home » Audio » General » Post Shopping Advice
Re: Post Shopping Advice [message #1931 is a reply to message #1914] Sun, 26 June 2005 20:56 Go to previous messageGo to previous message
Hi s7on3d,
After looking on the NAD website and the Stereophile recommended components list in the October 2004 issue. You may want take a look at the NAD C320BEEE compact reciever and add it to your component list.
The NAD C320BEE reciever, the Mission Beta 10's speakers that you mentioned earlier, along with a 10" Titanic MKIII subwoofer kit from parts Express should make for an ejoyable two channel system that will play classical music well.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-760
Madisound also, offers a decent entry level subwoofer kit that should work well with this sysytem. Got to madisound at: www.madisound.com and look on their kit page.
The Panasonic SAXR50 and XA55 are a few more recievers to check out on your search. http://www.pioneer.com
As others have advised you already, it is up to you to deside which system sounds best.
I personally like tube amplification, you can look on the used market at http://www.audiogon.com
If you search hard enough, you may find a good system at a good price, but patients pays off.
Good luck and happy hunting.
Norris Wilson
Previous Topic: Same great music on Vinyl vs. CD...
Next Topic: we 53A condenser mic power
Current Time: Tue Nov 17 17:17:55 CST 2026
