Home » Audio » Speaker » Conical HF Horn?
Re: Conical HF Horn? [message #19292 is a reply to message #19291] Fri, 15 June 2007 11:39 Go to previous messageGo to previous message
::I'm aware, though marginally, that a conical doesn't load well near its lower cutoff, so does this mean that a larger horn is needed to achieve the same cutoff as (for instance) a smaller CD-type horn?
Yes a conical horn will start cutting off appox. 20% higher in frequency than what the flare rate is. So you would need a larger horn to achive the same cutoff.
::I know that the horn has to be large enough to house the other speakers, but how much of it is needed to load the 1" driver?
I have no idea.
::And, if the coverage pattern were opened to 90 degrees, what might be expected for an off-axis response? Will it become beamy?
It would hold its pattern down the the cutoff of the horn but off-axis the higher freqencies would be more jagged in response and at a lower level. All horns start to beam at a higher frequency especially a conical horn (But I don't remember what the formula is). CD horns try to stretch the beaming out effect to the upper octaves where the ear's not a sensitive.
Previous Topic: JBL G-730 Diaphragm quest
Next Topic: passive crossover point
Current Time: Fri Oct 16 21:56:47 CDT 2026
