Home » Audio » Speaker » Determining Low Freq Cut Off Of Folded Horn Box
Re: Determining Low Freq Cut Off Of Folded Horn Box [message #19284 is a reply to message #19283] Tue, 12 June 2007 10:04 Go to previous messageGo to previous message
The lower cutoff of a folded horn is largely determined by path length. However, the shape of the flare and mouth size determine overall response. If there isn't enough mouth size to support the horn, response will be peaky and bottom end response may not be all that great. The flare profile also sets the response as does the size of the front and rear chambers and the electro-mechanical parameters of the driver.
Hornresp does an excellent job of simulating basshorns. I've used it for years with good results. A good Hornresp model will predict the response of a basshorn with +/- 1dB accuracy - far better than what most people can measure. So I suggest you might want to use this program to model your horn.
Previous Topic: Can car coaxs be used in line arrays?
Next Topic: thourght I'd show y'all my latest...
Current Time: Fri Nov 27 11:17:39 CST 2026
