Home » Audio » Speaker » Back from Dallas and depressed ...
Re: Standing wave notch [message #19244 is a reply to message #19243] Mon, 14 May 2007 14:56 Go to previous messageGo to previous message
DMoore is currently offline  DMoore
I think that LF drivers have a power-frequency bandwidth, that is, they are most efficient in certain topologies and that each combination of driver and loading topology is further bandwidth-limited or at least frequency-specific. Throw a crossover into the mix, and stir vigorously. Place in a room of unknown acoustic parameters...
I too have been on the search for the so-far-still-elusive low-frequency response combined with the appropriate ability to "punch".
Seems that if a particular driver is good at one end of the spectrum, it gives up the other. Getting a balance is a combination of the loading, the specifics of the driver and the crossover. The crossover is an important consideration in the mix, too.
Room suck-out could be a culprit, but if you had punch in the first place, it is unlikely that it would be removed completely. My opinion is that it is the particular driver/loading/crossover combination.
No clean answers to this one.
DM
Previous Topic: Shearer Horn adaptations for subbass use <100Hz
Next Topic: Anybody want to build a DIY IDS-25 clone (somewhat cheaply)?
Current Time: Sun Oct 25 02:26:19 CDT 2026
