Home » Audio » Speaker » ?More Horn Questions?
Re: ?More Horn Questions? [message #19208 is a reply to message #19205] Tue, 17 April 2007 21:51 Go to previous message
You don't have to really worry about what curvature might be approximated with Hornresp. Just model the horn using its actual dimensions and see what it does. About the pattern, if the horn has straight walls and is very large, then the pattern is set by the wall angle. When made small enough that the mouth acts as a diffraction slit at the lower end of the passband, then pattern will narrow slightly, then widen. By making a section of the flare near the mouth widen, you can reduce the narrowing of the pattern, just before the horn loses pattern control entirely.
Previous Topic: Large HEIL Drivers As A Line Source
Next Topic: DCA 5.5M drivers in PAWO horn: Bring to LSAF?
Current Time: Wed Sep 16 04:49:16 CDT 2026
