Home » Audio » Speaker » Lycra Horns
Lycra Horns [message #19195] Tue, 10 April 2007 22:44 Go to previous message
Cuppa Joe is currently offline  Cuppa Joe
I was perusing the Speakerplans website and happened across a thread in the New Projects forum in which a midrange horn was fashioned from Lycra.
The fabric was affixed to a wood frame to form the mouth, then a wood disk (from the throat cutout) was centered on the fabric and pulled from behind to stretch it into a horn. The frame shape and some strategic stitching gave the desired flare. The Lycra was then coated on both sides with layers of resin and fiberglass. Once dry, the throat was adhesed to the frame and the excess material was cut away.
The added bonus is that your horn can be any color you wish. Very clever!
Previous Topic: Consequences of non-optimal throat transition in mid and high frequency horns
Next Topic: Fostex surrounds?
Current Time: Sun Nov 01 03:26:39 CST 2026
