Home » Audio » Speaker » Consequences of non-optimal throat transition in mid and high frequency horns
Re: LC Peaking [message #19193 is a reply to message #19192] Sun, 08 April 2007 09:53 Go to previous messageGo to previous message
No, speakers are sound reproducers and should be as accurate as possible. They are to give the illusion that the instruments used are right there in the room with you, not add anything or take anything away. If you want to augment a certain track, instrument or music range, then you can use EQ to do it. But ideally, your speakers are capable of being sonically neutral.
Previous Topic: TANNOY WESTMINSTER for auction, buy or not?
Next Topic: Lycra Horns
Current Time: Fri Nov 06 06:11:32 CST 2026
