Home » Audio » Speaker » Consequences of non-optimal throat transition in mid and high frequency horns
Re: Consequences of non-optimal throat transition in mid and high frequency horns [message #19177 is a reply to message #19176] Mon, 19 March 2007 11:53 Go to previous messageGo to previous message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi Wayne,
Thanks a lot for your reply!
To be more specific: In my horns the first 3/4 of an inch (the "adapter")is not flared at all, but resembles a "tube" (I hope it is possible to visualize my description!). After that, the circular entry is slowly (over a distance of app. 2 inches) converted to the rectangular form of the exponential horn. This transition piece is fairly smooth, but not perfect.
Given your expertise, do you find it likely that a "transition" as described above would (or could) course harshness in the 6-9 kHz range (in my case, especially too pronounced s-sounds in female voices)?
Thanks again Wayne!
All the best
Peter
Previous Topic: TANNOY WESTMINSTER for auction, buy or not?
Next Topic: Lycra Horns
Current Time: Fri Nov 06 06:11:30 CST 2026
