Home » Audio » Speaker » 1:1 throat area
Re: 1:1 throat area [message #19118 is a reply to message #19117] Thu, 22 February 2007 11:49 Go to previous messageGo to previous message
Klipsch's rubber throat does that, you're right. But as you've said, it was done on undersized basshorns (smaller than 1/4λ) having compression and a front chamber. Might be useful on a smaller scale for a midhorn though, so I think it was worth noting. Good call.
The use of changing wall angle to increase uniformity of a constant directivity horn is a different matter, because it addresses the loss of pattern control. What CuppaJoe is talking about is widening a very small area near the throat. This will not widen or narrow the pattern at any frequency. It might cause a reflection at high frequency, hopefully, out of band. But the pattern would not be set by this feature because the rest of the wall angle constricts radiation to a narrower pattern.
Previous Topic: comb filter distorsion
Next Topic: Adding Tweeter to Full Range Driver
Current Time: Sat Oct 17 05:08:58 CDT 2026
